Dvd Players
Shifty
Does anyone know if the nav units are able to play dvds if you changed the screen?
I dont need the use of the nav unit as I work for a sat nav company so have access to the latest one all the time. So thought I would utilize the area and have it as a dvd player
Yes. Best option is the 7" variant; you just take it apart, remove the screen to leave an empty housing, then buy a 7" LCD screen with AV input, take the casing apart on it and mount it inside the sat nav housing, wire in for power (most take the power line from the stereo power harness), run an AV input from it to a DVD player (which will also need a power supply) and boom; DVD playback in the standard housing.
You can do it with the earlier, 5" variant, but you're more limited on screen choices
