Rear Suspension Arm Dony Know What Its Called
black400
i need to get this part its marked with the orange paint ,can any one tell me what it is called,i sent this pic to Lexus Galway they only gave me a price? no description.i think its the one in the diagrame nxt to
the circled pic item no 48720A
Hi
The part you are showing in the photograph is the rear no1 lower suspension arm and the bit marked 0range is the cam and bolt body side. If they are saying the bush needs replacing then you will probably have to buy the whole arm.
Make sure you set the cam to the position(mark it with a sharp point) it is now when replacing the arm or your suspension settings will be out
