I have a '94 GS300 and it has been laid up for the last 11 months.
After a quick Battery charge it started immediately on first turnover this morning - but it is running lumpy.
Forgive my mechanical ignorance, but I would describe the problem as the same sort of lumpiness when a four cylider is firing on 3 cylinders.
Can anyone suggest what the issue may be (hopefully it it not overly complicated) so I can start some diagnosing.
Thanks.
Ok -today had time to look for the problem.
I took off the front and back covers to get access to the spark plugs and ht leads - and there it was - a mouse nest.
During the short time I had the car parked up, the mice had built a nest under the rear cover and chewed completely through the HT lead to the rear sparlk plug.
I repaired the lead using a sewing needle and some insulating tape, but obviously now need to replace the lead.
Anyone know the best place to get a replacement lead from ????
Perhaps a local motor factor could supply one the correct lenght and with the correct connections or a local breakers yard.
Most HT leads are sold as a set.
Have a look at these to see if it is the same as yours.
http://www.ebay.co.uk/itm/LEXUS-GS300-3-0-24V-DOHC-97-05-2JZGE-ENGINE-SPARK-PLUG-IGNITION-HT-LEADS-WIRES-/170718914305?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bfa3e701#ht_1841wt_1189
