Steering Wheel Fix And Is Wheels
Hi guys and girls the steering wheel on my 99 LS400 rises and lowers but wont reach and go back there is no sound of motors e c t.Its annoying as i am six six and i would like it back in as far as it goes , Is there a fix.
Plus is it true that the alloys of a is200 will pit without any mods...
On the later models it is normally the motor that fails at around £300.00! But apparently the Toyota Landcruiser uses the exact same motor for considerably less.
A lot of owners have removed the motor, manually wound the gear to retract the steering wheel and then refitted the motor disconnecting the wiring loom to it.
Not sure about the IS200 wheels due to the large front brake calipers on the LS400
