Wheels How Wide Can You Go?
marky boy
Will 8.5 wide alloys fit an is200 sport without arch work? Bearing in mind its 15mm lower as its a sport model
want to put these on my car ! With wobble bolts
will the offset ect b ok?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=280672090202&index=8&nav=SEARCH&nid=08753541052
The offset looks OK but the bore is larger so you will need some spigot rings 66.1.to 60.1 also the PCD is 112 on Mercedes opposed to 114.3. As you realise this will need the fitment of wobble bolts, from a personal view I wouldn't like the thought of these holding my wheels on.
Personally I would find some wheels of the correct fitment.
Aye a knw about the wobble bolts some cars come out factorys with them mate !
Just want summit different was lookin at wheel adaptors but then the spacer will be like 20 mm so that would fuk things up surely ?
