Hi
i have a is220d and when i walk up to it drivers side, only the drivers door unlocks. is it possible to change that so all of them unlock.
does it need to be done at the dealers?
thanks
Take a look at this Sound is crap but it will explain it to you. Hope it helps
Before changing anything, check that your entry system hasn't been set to "one click - opens driver door only, second click opens the remaining doors". This is a security option so that the passenger doors do not offer carjackers and other criminals an easy entry into the car.
  • 1 year later...
Nope. Not working on mine is220d "08. Tryed several times, even showed on the dashbord the car with all doors open figure and still..only driver door its opening :-#(
I wonder how you get the 'beep' to work when you lock and unlock the doors? That car in the first video looks to be a 2011 Model year F sport. I have a 2011 Model year SE-L and it doesn't do that
  • 8 months later...
no beep on my 2008 also, it locks and unlocks fine (when i approach with the key the drivers is unlocked first, then all the others unlock).
how do you get a beep.?! the lexus is crazy with all the options
some of these options are only dealer programmable. Also certain features are only available in specific countries.
I wouldn't mind this beep but I'm guessing it can't be done in the UK then?
Its not set up for uk, doesnt bother me anyway, who needs a beep
folding mirrors is good enough for me for now!
  • 2 years later...
I just tested that it does work and you do get a beep after 10 seconds.
Not sure if it has resolved my issues regarding locking/unlocking the car time will tell
My problem isn't unlocking all four doors when I get in, its when passengers want to get out, and they can't!
Instead of their doors simply opening automatically for them to get out, I have to press the central locking button to release the lock on their doors, unless they know to pull back the lock by the handle.
Is this something I can change myself, or is it a dealer only job?
This morning if i tried unlocking the car from the passenger door handle or the remote key  it wouldn't unlock any of the doors apart from the drivers, I had the same issue last night. I have the same issue when letting passengers out sometime.
What I have done now is swapped my remote key I going to test it with my spare key and see how it goes so far its ok but its a very tempremental thing sometimes it works sometimes it doesn't.
If that don't work I might just disconnect the Battery over night and see if that helps very adoubt it failing might be a visit to lexus as I see many people are having this issue.
