hi guys with all the frosts we have been having went out in my gs300 sport this morning 1st for 2 weeks and i have got a bit of condensation on the inside of my front windscreen first time this has happened is this a problem or not
many thanks kev.
If the car is kept outside I would say with the cold air inside the car it would be normal but check your carpets for signs of damp just in case there is water getting in somewhere.
If you can't find anything specific to cause it try some moisture absorbent crystal packs ( silica gel or similar) on the dash.
Not unusual for this to happen especially if the heater has been generating warm air before you leave the car. Take a look at other cars parked outside and quite a few will be the same.
