hi could you tell me what type of interior bulb lights are in rx400. looking to swap them for LED lights (interior,boot and number plates lights)
thanks for help
Not so sure you can swap the interior bulbs, well you can of course but if you swap the filiament bulbs for LEDs you will loose the fade out function.
Also be aware that you may get a "bulb failure" warning with exterior lamp swaps unless you make sure you have "loaded" LED bulbs.
