New Headunit
AdamBu
Well i have wanted one for a while, So just gone out and treated myself to this http://www.cartuningparts.co.uk/jvc-kw-avx740-double-din-multimedia-system-with-full-speed-ipod-control/
Will it be plug and play or will i come across any problems.
Like will i need a facia or another wiring loom
that is the same one i used,if you want to double check,remove plug from rear of amp if you have 2 small plugs you need other lead,if you have one small and one large thats the right one, The amp is located behind glove box left hand side.
