Gs Stereo Help
You don;t say whether you have SatNav or not - but it's probably very similar.
Pull out the ashtray and it's housing (give it a good pull and it'll come out)
Pull out the vent assembly above the radio - lever the edge free with a small screwdriver and then pull it out.
You'll see 10mm bolts above and below the deck - take them out and the whole unit will come out (obviously after unplugging the wires)
