Current Mods To Is200
Barry XXMM
LLooking good. Youve inspired me but I used leds in my fogs for a the more suttle drl look. I think ill paint my calipers black and then I want the decals type that curve round.
Where did you get dial chrome rings? And do all the dash light just use t5/t10 bulbs and simple swap?
Purchased off a nice member on here last week :)
As for the dash bulbs just a mixture of T5/10 in blue smd from eBay....
Red arrows showing the position of the 3xRed 501w/T10's ,Yellow arrows 2xT5/286 led's (very small)
bulbs for IS200 99-
Dip Beam - 9006/HB4
Main Beam - 9005/HB3
Sidelight - 501w /T10/W5W
Side Turn - 501w /T10/W5W
Front Fog 99-2003 - 9006/HB4
Front Fog 2003- H3
Front Turn Indicator - T20 /7440/582
Rear High Mounted Stop Light - 955
Licence Plate - 501w /T10/W5W X 2
Rear Fog - T20 /7440/582
Reverse light - T20 /7440/582
Rear indicator - amber 582y/7440/T20
Stop/Tail - R580 /w21\5w
Interior Middle Dome - 269 /festoon 31mm
Interior Front - Ba9
Glove Box - R286 / 5mm
Ignition barrel ring - R286 / 5mm
Door Marker lights - 501w /T10/w5w
Boot Light - 501w /T10/w5w
For the heater controls you'll need this type,
But if you replace the stock bulbs with these most people find them not bright enough!
Theres a tut on another forum that works so much better, but its a PITA of a job to do but well worth it.
This is what you'll end up with with that better mod.
Changing the radio will be a royal pain in the ar$e as its leds are soldered to the board.
If you look at the pic below i belive that they are the samest smd LED in the pic lol feck that!!!
Someone has do this mod and swapped them to blue and it looked spot on, but id never have the patience to do it.
  • 1 year later...
523519_10151089261796712_2107988280_n.jp
If you look at the pic below i belive that they are the samest smd led in the pic lol feck that!!!
- Where can i buy the small diodes you show a picture of ? :D and what's there name?
Also what about the dimmer for the dash light and also the car dims the A/C lamps when switching on the ligts? - i guess the diodes dosent dim? do they just turm off or burn out or what happes? and if they go out or die what to do about it?
  • 4 months later...
