Hi, I've been trying to find a topic without success so ill just ask the question.
If anyone has a 2011 rx450h and tow's a caravan,do you know the max weight on the towball?
The 400h was 80kg and not sure if its the same or more
I would imagine that it would be very similar to the 400h. Generally, for a safe tow, work on around 7% of the Actual Laden Weight of the caravan as a guide to the best noseweight. I am sure that your Lexus dealer or the Caravan Club could give you recommended noseweights as laid down by Lexus.
Thanks for both replys.
According to the fitting instructions, the nose weight is indeed 80kg :)
Andy
