Online Guides
Hi all,
Are there any online guides for changing the headlight bulb on the IS200? Specifically the side light as I noticed my nearside sidelight bulb has gone. I used to drive a mondeo and changing the headlight bulbs on that were a right chew on as you had to remove the front grill to get it out.
Any links etc that anyone knows of?
Cheers
Peter
Hi Peter,
if you click this link you will have all you need to know.
UPDATE: It only seems to work in IE though!
Dave
Thanks for that link Dave, bookmarked.
I had a closer look today and it turns out I just needed to twist the power cable connector counter clockwise and it came straight out. Changed it in about 2 minutes.
