i bought a hks silent high power exhaust for my is200 in july. im pritty sure it said it was a cat back exhaust system when i bought it. now the silecer between the cat and the exhaust has broken. does anyone know where i can get this bit from or even a pipe to peplace it so i can get some noise from the car?
you can take the cat out and the turbulence can on the hks silent power still keeps it low. you may be better going for a custom system if you want noise.
i'll buy your hks one tho ;)
im sorry but im no selling my hks i like it too much
all im needing now is a straight pipe between my cat and the exhaust as mine is broken :(
Well if the exhaust pipes are standard they should be 2.25 inches diameter. you can buy stainless steel pipe by the metre in most metal yards and maybe pop into some where like quik fit or humphreys. if they havent got any then im sure they can reccomend somewhere local to you.
