Altezza Rs 200
DJBOZ
hi to all i own a altezza beams 3gse rs 200 the car drives perfect just had it serviced but when the car comes of choke the idle is not stable. it dips sklightly but does not cut out. not sure if this ios realated but the car has developed a flat spot as soon as you accelerate. can some one help as the local garages in my area are doughnuts. thanks in advance.
  • 4 weeks later...
If you'd had a look in the Altezza section you probably would have found the answer already. Clean the MAF sensor & throttle body...
