Every so often, I turn the key to start and nothing happens. All the lights come on as normal, wheels moves but its same symptom as trying to start in D.
Battery is fine. When it starts normally it spins over no problem. If I flick the key a few times, it fires but if I hold the key at start and move the gear lever fom D to N then it will fire as well. Not sure if its inhibitor switch or ignition switch. Either way, its only going to be a poor connection. Has anyone experienced it and can point me in the right direction?
