Just wondering if it is ok to put the pink Coolant (Super Long Life) into the system after the water pump etc is changed? I know the car has the red one in at the moment but surely it would be better to use the pink one as it lasts longer?
Cheers
Ask your Lexus dealer how compatible the 2 colours are. If you decide to go over to pink, you will probably have to drain and flush the red stuff out first.
i would go with the red anti-freeze.
either way, drain & re-fill new coolant.
