Led Replacement For Is200 Indicators
thalystgv
Hi i know this topic has been covered but im still confused. Not too much detail on exactly how to do this. Prehaps someone can write a complete guide so an idiot like me can understand it easily.
I have ordered front indicator SMD replacements as i have de-tangoed my front lights.
Side Indicator LEds i already have.
Rear bulbs im a bit confused with, What is the uk model type. I want to use SMds also are the pins on the bottom of the bulb opposite or off set. Can anyone recommend the right bulbs
I would like to use an LED flasher relay ive seen for about £8.
Dont want to mess about with load resistors. So i can revert it back to standard if i need to.
I have looked in the drivers footwell fuse box and cant see the relay. I can hear it when the indicators are on.
What does it look like and how many pins are on it? and how easy is it to remove.
Thanks in advance for any relies.
Just want to add a bit of moderness to the car.
