Will Not Start : (
Hi all
new to this...
right where to start,the other half was driving my is200 99/00 navi crashed (nothing major) took the back wheel out and back door and a bit of sill (lost control on oil patch not used to driving rear wheel drive cars) this was 3 years ago i have a few cars so this was left in one of my warehouses awating repair i have now got round to having it fixed a bit of welding here,new wish bone,door etc the cars Battery went flat...
we have now come to starting the car and had no luck
i have had the world and his wife look at this car the problem is the car will lock/unlock off the key all light/raido work all the boxes are ticked for the car to do as it should BUT the car go's to turns over as it should but wont fire up the security light on the dash flashes away all of the time (even when the key is in the barrle) (unless i arm the alarm then it stays on for 50/60 seconds and then flashes as it should i have had:
new Battery in car and key
had an auto elec look at the fuses (not the best auto elec in the world)
had the ecu flashed/reprogramed/then virginated???
then got a 2nd ecu incase the old one was damaged?? and did all the above to this one
new key programed into the ecu and am sure there is 1 or 2 other things
but nothing changed i have put quite a bit of money into this now and dont just want to give up on it the car is like brand new again but this problem is realy begining to get under my skin any one got any ideas??
i am thinking of immobilizer module/fuse i have a beginer level knowledge of cars but nothing major dont realy want to put it into the stealers for them to want to put another ecu in to it
I'd be tempted to go back to basics and make sure that fuel is getting through and that your getting ignition to your plugs. Seems strange that your car didn't break down and that, presumably, you could drive it after the crash. There may be someone else along to give you more professional advice. Best of luck.
Thanks mate it's just that security LED flashing that is giving me the problem would you know if there is a relay or module for the immobiliser ??? Think my only option it to give it to a lexus approved garage to plug it in there's nothing worse than the people who have come to look at it have been friends of friends who think they can fix it but don't get any luck with it
Thanks for the reply any way mate ; )
If you've checked the basics then it might be your best option. They will probably charge you for the diagnostics but if it identifies the fault then it is money well spent. Johnson's in Bootle are pretty helpful and the prices are reasonable - for a Lexus dealership.
hi thanks for the dealer info i am going to give it one last go my self befor i put it in with the main stealers : ) i have just orderd one of theses UNIVERSAL HANDHELD CAR FAULT CODE READER - EOBD OBD2 things
only penny's so its worth one last swoop before i go in and get lube'ed up for a right good shafting by lexus them selves :crybaby: if the car was fairly new i would have no problem with putting it in but its getting on now let you know what the out come is can i find out what the falt codes are on this web site???
again thanks
