Urgent Help Needed!
Hi everyone,
I hope you are all well, I am in need of some help with my IS200 if possible?
I am in desperate need of some advice, I have a Lexus IS200 and it has been so good to me however recently the steering has felt a bit 'flakey' this had turned into a rapid deterioration and the car is all over the road (literally).
So I got under the car and had a look, basically the front two shocks are completely shagged (See pics, they say a thousand words.) The backs seems fine.
The car has only done 82k however I am not surprised the shocks have given out as the car has 50mm lowering springs on.
Okay, so the ideal situation is get coilovers and all is well, but I cannot afford them at the moment so will have to be replacement OEM for now. I appreciate that putting 50mm lowering springs onto the new shocks will ultimately lead them to the same fate but at the moment I don't have a choice.
My questions
  • Replacement ones I am looking at say KYB Gas however the current ones are clearly oil, will this be a problem?
  • Will I need to replace the rears as well, even though they are not showing signs of leaking.
  • How much should a garage charge to do this? One wanted an hour and a half PER SIDE?! at £80 per hour.
Also to add insult to injury my passenger side lower ball joint seems to be on it's way out as there is an oily substance around it, again I know these will need to be replaced it pairs. Cost wise does it make sence to get this done at the same time?
Thanking you all kindly!!
Hi mate, thanks for your reply. I was going to have a crack at it myself but I have been told I will need a spring compressor plus a ball joint breaker? Plus I will need the alignment re-doing so I might see if Tony @ WIM will do it for me as they set the alignment up for me when I originally got the car.
Okay mate, well I've emailed Tony to see what kind of price I am looking at- If it's expensive I will give it a crack myself.
The shocks I am looking at are 'Excel-G/Shock Absorber' from buypartsby.co.uk
Do you reckon the rears will be okay? There's no sign of them leaking, also should I replace both bottom ball joints, are they easy enough?
Thanks so much for your help.
AMD at Lakeside, Essex installed my coilovers (front and rear) and aligned the wheels for £200+VAT about 2 weeks ago.
Before that, I rang around a few places and one quoted me £80 + VAT per corner!! That's £384!!!!
I told them to jog on!!!!! B)
