Radio Problem Gs300 1995
On my 1995 GS300 the sound on my radio/CD/tape is not working yet the display is normal and they are all working as normal. Is there a seperate fuse for an amp, if so, where is it?????
Or could there be another problem??? Any help would be GREAT as the silence is driving me to the brink of insanity!!!!
The amp is a separate unit in the boot under the changer unit. It has it's own fuse labelled as "AMP" from what I remember.
Thanks ,It would be a great help if you could remember were that fuse is. YES I am a dimwit!!
I think it is in the fuse box in the drivers footwell. The fuses are labelled on the fusebox cover.
Could be the system has muted because it thinks your on the phone?
We're so good on the LS forum the GS members are coming over to us!! lol
There was a known problem with the LS phone interface causing muting to the sound system due to damp entering the plugs under the rear seat squab but not sure on the GS.
