Made A Video
is that just a supercharger that has increased that performance? that time is pretty quick
if that is the case, why don't they make an IS200 Kompressor, i think it would frighten those little C200 Kompressors away!
I seem to remember it doing 5.9 when I was in it :o
2 people = extra weight = extra grip?
:iraqi-info-minister:
clutch wasn't slipping when you were in the car, once a new clutch is in place it should be better. higher revs on launch required as well - video launch was at about 2,500rpm should be approx 3,000 rpm for good launch i've found.
nah no more money :(
beside all i need is bigger injectors and then i can run 14psi :)
currently on 10psi 140kw rear wheels. 14psi can give 157kw rear wheels and still going strong, but running lean. So bigger injectors baby :)
hey i was looking at your video, ur are using the forst option for measurement right?
I use to use that but then found out that the 3rd option "XXX K " can configure it from 0-100km/h to 60-100km/h yesterday.
