just had two front lower ball joints replaced new.
now the ABS light is on & the TRC is flashing.
any ideas what could it be ? . . .
That means theres a fault with the ecu.
Need to get it plug in and read the code to see whats wrong would think they might have caught something when swapping parts
when you say caught in something, is that the abs sensor wire (damaged) ?
is there point in disconnecting the Battery for a while ?
last option i will get the diagnostic done.
also i assume the wheel allignment is out as the car feels wobbly now, when driven.
45views & 2replies!
anyway, problem fixed.
had a doubt on what it was & thought make it easier by asking on the forum as im a very busy man.
thanks mattc
  • 11 years later...
