my lexus 2003 rx300 driverside wing mirror will not go to its proper position when switch on,it will go all the way round and the mirror will face the front,any idears how to fix it,many thanks
Unfortunately I have the same problem with mine,I caught it while reversing onto my driveway which is a tight fit.I took it to my local Lexus dealer and demonstrated what was happening.He suggested the mounting for the motor that drives the morror had broken thereby causing it to go past its stop.I took it to bits in order to make a repair but the motor itself is sealed.So as a short term repair I have disconnected the drive motor and super glued the swivel into position.This maintains a fixed position but allows everything else to work.I priced a new mirror(with glass)£550.or £260 from a breakers.
