as the usual problem, the cd player has packed up again!
IS200se 2000
its not an error 3 message, instead it says 'waiting for disc' when i press the load button.
a cd cant be inserted.
im assuming its the cogs in the unit, would like to confirm tho -
It sounds very much a mechanical misalignment of the loading mechanism,plastic gears don't last.
Problem now days is you cannot easily get manufacturer's technical support so repair and realignment are more or less impossible,years ago I could strip down a Pioneers 6 disc player replace the problematic spindle motor and realign in 30 minutes but I did have the service manual to hand and better eyesight!lol
