Cd Changer Audio Problem
evoskii
I am new to this site, and i have recently purchased an IS200 estate 2002 plate. The speakers work fine all round including balance and fade when in radio mode. The problem is when i play a cd only the right side speakers work. Is this due to a faulty system or loose wiring maybe inside system. Would love your advice on this. Also where is the fuse for the window washers.
Other than these couple of minor problems im very happy with this car, its my 2nd IS200, the 1st was the saloon model 2000 plate.
Many Thanks
Paul
Hi mate and welcome, not a clue about your radio prob, but have you tried the button on the end of the wiper stalk? Took me a while before i found out how to work the washers!
If you,ve tried that and its full of fluid and your getting the sound from the pump but no water you may have an air lock?
Hope this helps.
Martin
