Altezza Misfire **urgent**
crafty_carper
Right just a quick question, found out it was a coilpack that had gone. I read on here that the IS200 coils were the same so went out & got 1 of them.
Put this on my engine, fired it. Still running on 3 cylinders & engine management light flashed up.
The part numbers on the coils for the Altezza & IS200 are different. Is anyone sure that they are interchangable with both cars or is this not true?
Part no. for altezza is 90919-02236
Part no. for IS200 is 90919-02230
Any help much aprecaited
Tom
I can't say I've ever heard that one. They're most definitely different coil packs between the 1GFE & 3SGE.
You can run a coil pack from a ST215 3SGTE alright in an Altezza if you're caught short but it's advisable to run the correct one. Supposedly the IS-F runs the same coil packs :lol:
