Tte Rear Skirt Easy To Fit ?
jason blake
Fitted one last week for a customer, should come with a full fitting kit comprising bolts, screws and a rubber trim/gasket.
You will need to remove the bumper, put a blanket on whatever your work surface is to prevent scratches,
on the inside of the bumper you should be able to see markings for drilling the holes,
use a six mm bit to drill, from the inside out,
press the bolts supplied into the brackets on the skirt and fit the gasket, then offer it up to the rear bumper and fit the blots through the holes you have drilled,
put the nuts onto the bolts,
Now drill two 1/8 holes at each corner where the mudflaps would go and fit a couple of self tapper screws.
Hey-presto, job done.
Refit your bumper
