On 5/2/2017 at 11:01 PM, Ash85 said:
Hi guys.
I owne a is200 51 plate.
I bought the car last year. Now the car done 160k.
Last time timing belt got done was on 96k. No problem with the car.
How ever recently I noticed the car usin lot more fuel than usual !
Any one can advise me about unusual fuel uses?
Yes check for the cat, all of them, go to my profile and check my posts it might help you
  • 6 months later...
On 9/16/2011 at 5:19 PM, XK8BMWLexus said:
hi all
new member to this forum and new owner of a Lexus IS200 2002
can i join in and ask a question for a problem that has arisen.
the steering seems to 'judder' when turning. this only seems to happen when the car is started from cold. this seems to clear by the time i've reached the end of the road.
any suggestions as to what the problem may be?
thanks in advance for any suggestions
terry
Make sure its steering pump 'fan belt' is tight.
On 7/18/2011 at 12:44 AM, nicki d said:
Hi I have a big if wobble from steering wheel at 60 and alot when I brake. Did you have this with seized calipers
Common problem across all types of cars would be proper balancing of wheels.
  • 4 weeks later...
Hello there I’m looking to buy a Lexus Is200 is there anything that I should be looking out for on these cars The car does come with full service history just wanted to see if there is anything else
  • 5 months later...
Have owned a couple look out for:
rusty sills
if the Cambelt has been replaced
The head unit plays up normally the changer that fails.
alloy wheel corrosion.
 I was lucky enough to own a 2001/51 is200 manual with factory trd kit in black with full black leather. Sadly she’s no longer on the road 🥺
  • 1 year later...
Thank you for all the helpful hints regarding buying an is200 they are very much appreciated
I bought an 03 is200 se aero 91k FSH 👍🏻
i will be looking to add some is200 sport upgrades inc the silver pedal and footrest pads and the sill scuff trims ,and a  sport rear spoiler
  • 1 year later...
I have a 2002 IS300. It goes through a lot of tyres, no-one locally can sort the geometry.
Error 1 on the CD player can be solved by using a CD cleaning disc.
It's a great car, enjoy it!
P.S. I can't speak highly enough of Osaka Newport, independent Toyota / Lexus workshop; it's in what looks like a dodgy place, but this guy is Lexus-trained, and committed to repairing problems at minimal cost.
