Anyone know what this maybe on mk1 gs300 sport
Most of the dash lights came on last night, orange oil light, Battery light, tail light out warning light. the only 2 which i think didnt come on is the red oil and abs light ??
Most of the dash lights came on last night, orange oil light, battery light, tail light out warning light. the only 2 which i think didnt come on is the red oil and abs light ??
Happened to me once in a Granada, the alternator belt was slipping and the Battery
voltage was too low.
Also check if Battery is faulty
yes i agree, check belt first then Battery then alternator in that order, but also check crank pully thats if it the same as mk 2 mine had parted and had new Battery aternator reconned new pully tentioner and after all that it was the crank pully. start you engine up let it run for a short while then turn lights on radio on air con on and turn your wheels to full lock if you get some one to look at your belt while you put t on full lock, the belt may even stop and lights will come on then then i would say it crank pully parted thats if it the same as mk2, hope you sort it
Now its stopped raining, discovered the distributor oil seal is leaking and dripping in alternator, sprayed carb cleaner in it and seems to be working again at mo.
