Wanted...mobile phone ...subject matter ends way o
Fidgits
  • Replies 113
  • Created
  • Last Reply
Top Posters In This Topic
ok here goes, not as intense as solid fuel rockets....
Turbochargers are a type of forced induction system. They compress the air flowing into the engine The advantage of compressing the air is that it lets the engine squeeze more air into a cylinder, and more air means that more fuel can be added. Therefore, you get more power from each explosion in each cylinder. A turbocharged engine produces more power overall than the same engine without the charging. This can significantly improve the power-to-weight ratio for the engine.
In order to achieve this boost, the turbocharger uses the exhaust flow from the engine to spin a turbine, which in turn spins an air pump. The turbine in the turbocharger spins at speeds of up to 150,000 rotations per minute (rpm) -- that's about 30 times faster than most car engines can go. And since it is hooked up to the exhaust, the temperatures in the turbine are also very high.
Basics
One of the surest ways to get more power out of an engine is to increase the amount of air and fuel that it can burn. One way to do this is to add cylinders or make the current cylinders bigger. Sometimes these changes may not be feasible -- a turbo can be a simpler, more compact way to add power, especially for an aftermarket accessory......ala the monster!
Turbochargers allow an engine to burn more fuel and air by packing more into the existing cylinders. The typical boost provided by a turbocharger is 6 to 8 pounds per square inch (psi). Since normal atmospheric pressure is 14.7 psi at sea level, you can see that you are getting about 50 percent more air into the engine. Therefore, you would expect to get 50 percent more power. It's not perfectly efficient, so you might get a 30- to 40-percent improvement instead.
One cause of the inefficiency comes from the fact that the power to spin the turbine is not free. Having a turbine in the exhaust flow increases the restriction in the exhaust. This means that on the exhaust stroke, the engine has to push against a higher back-pressure. This subtracts a little bit of power from the cylinders that are firing at the same time.
The turbocharger also helps at high altitudes, where the air is less dense. Normal engines will experience reduced power at high altitudes because for each stroke of the piston, the engine will get a smaller mass of air. A turbocharged engine may also have reduced power, but the reduction will be less dramatic because the thinner air is easier for the turbocharger to pump.
Older cars with carburetors automatically increase the fuel rate to match the increased airflow going into the cylinders. Modern cars with fuel injection will also do this to a point. The fuel-injection system relies on oxygen sensors in the exhaust to determine if the air-to-fuel ratio is correct, so these systems will automatically increase the fuel flow if a turbo is added.
If a turbocharger with too much boost is added to a fuel-injected car, the system may not provide enough fuel -- either the software programmed into the controller will not allow it, or the pump and injectors are not capable of supplying it. In this case, other modifications will have to be made to get the maximum benefit from the turbocharger.
How a turbo Works
The turbocharger is bolted to the exhaust manifold of the engine. The exhaust from the cylinders spins the turbine, which works like a gas turbine engine (see Dr mats earlier topics) The turbine is connected by a shaft to the compressor, which is located between the air filter and the intake manifold. The compressor pressurizes the air going into the pistons.
The exhaust from the cylinders passes through the turbine blades, causing the turbine to spin. The more exhaust that goes through the blades, the faster they spin.
On the other end of the shaft that the turbine is attached to, the compressor pumps air into the cylinders. The compressor is a type of centrifugal pump -- it draws air in at the center of its blades and flings it outward as it spins.
In order to handle speeds of up to 150,000 rpm, the turbine shaft has to be supported very carefully. Most bearings would explode at speeds like this, so most turbochargers use a fluid bearing. This type of bearing supports the shaft on a thin layer of oil that is constantly pumped around the shaft. This serves two purposes: It cools the shaft and some of the other turbocharger parts, and it allows the shaft to spin without much friction.
There are many tradeoffs involved in designing a turbocharger for an engine.
Too Much Boost
With air being pumped into the cylinders under pressure by the turbocharger, and then being further compressed by the piston , there is more danger of knock. Knocking happens because as you compress air, the temperature of the air increases. The temperature may increase enough to ignite the fuel before the spark plug fires. Cars with turbochargers often need to run on higher octane fuel to avoid knock. If the boost pressure is really high, the compression ratio of the engine may have to be reduced to avoid knocking.
Turbo Lag
One of the main problems with turbochargers is that they do not provide an immediate power boost when you step on the gas. It takes a second for the turbine to get up to speed before boost is produced. This results in a feeling of lag when you step on the gas, and then the car lunges ahead when the turbo gets moving.
One way to decrease turbo lag is to reduce the inertia of the rotating parts, mainly by reducing their weight. This allows the turbine and compressor to accelerate quickly, and start providing boost earlier.
Small vs. Large Turbocharger
One sure way to reduce the inertia of the turbine and compressor is to make the turbocharger smaller. A small turbocharger will provide boost more quickly and at lower engine speeds, but may not be able to provide much boost at higher engine speeds when a really large volume of air is going into the engine. It is also in danger of spinning too quickly at higher engine speeds, when lots of exhaust is passing through the turbine.
A large turbocharger can provide lots of boost at high engine speeds, but may have bad turbo lag because of how long it takes to accelerate its heavier turbine and compressor.
The Wastegate
Most automotive turbochargers have a wastegate, which allows the use of a smaller turbocharger to reduce lag while preventing it from spinning too quickly at high engine speeds. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure. If the pressure gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
Ball Bearings
Some turbochargers use ball bearings instead of fluid bearings to support the turbine shaft. But these are not your regular ball bearings -- they are super-precise bearings made of advanced materials to handle the speeds and temperatures of the turbocharger. They allow the turbine shaft to spin with less friction than the fluid bearings used in most turbochargers. They also allow a slightly smaller, lighter shaft to be used. This helps the turbocharger accelerate more quickly, further reducing turbo lag.
Ceramic Turbine Blades
Ceramic turbine blades are lighter than the steel blades used in most turbochargers. Again, this allows the turbine to spin up to speed faster, which reduces turbo lag.
Sequential Turbochargers
this is whats fitted to the supra.
Some engines use two turbochargers of different sizes. The smaller one spins up to speed very quickly, reducing lag, while the bigger one takes over at higher engine speeds to provide more boost.
Intercoolers
When air is compressed, it heats up; and when air heats up, it expands. So some of the pressure increase from a turbocharger is the result of heating the air before it goes into the engine. In order to increase the power of the engine, the goal is to get more air molecules into the cylinder, not necessarily more air pressure.
An intercooler or charge air cooler is an additional component that looks something like a radiator, except air passes through the inside as well as the outside of the intercooler. The intake air passes through sealed passageways inside the cooler, while cooler air from outside is blown across fins by the engine cooling fan.
The intercooler further increases the power of the engine by cooling the pressurized air coming out of the compressor before it goes into the engine. This means that if the turbocharger is operating at a boost of 7 psi, the intercooled system will put in 7 psi of cooler air, which is denser and contains more air molecules than warmer air.
the principles of a supercharger are similer than the turbocharger, the biggest difference being the supercharger is driven by a shaft or belt from the engine and not by means of waste exhaust gasses
I learnt that:
Rocket science isn't as hard as it sounds
How a turbo works
Posting smilies gets your number of posts up really quickly
Some people know far too much telephony history
Synchronizers
Manual transmissions in modern passenger cars use synchronizers to eliminate the need for double-clutching. A synchro's purpose is to allow the collar and the gear to make frictional contact before the dog teeth make contact. This lets the collar and the gear synchronize their speeds before the teeth need to engage.
Cheers, I think I understand.?!?
BTW I still can't do 'nesting' despite Ryan's and Asam's help. :iraqi-info-minister:
I just doesn't come out right for me, like this :
QUOTE (Fidgits @ Jun 17 2003, 08:33 PM)
QUOTE (TonyGoose @ Jun 17 2003, 08:32 PM)
QUOTE (Dr Evil @ Jun 17 2003, 06:40 PM)
How 'bout synchromesh? I've never been able to get my head round that.
Well that's a mechanism to stop gears crunching when you change between them ...
So, Lexus should think about installing it in the IS200 sometime soon
hmm... have you tried depressing the clutch between gearchanges?? might help
Can someone explain it do a dunce like me?
clutches
If you drive a manual transmission car, you may be surprised to find out that your car has more than one clutch in it. And it turns out that folks with automatic transmission cars have clutches, too. In fact, there are clutches in many things you probably see or use everyday: Many cordless drills have a clutch, chainsaws have a centrifugal clutch and even some yo-yos have a clutch!
but were intreted in the manual gearbox clutch.
Why Do We Need Clutches?
Clutches are useful in devices with two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft is driving another device. In a drill, for instance, one shaft is driven by a motor and the other is driving a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds
In a car, you need a clutch because the engine spins all the time and the car wheels don't. In order for a car to stop without killing the engine, the wheels need to be disconnected from the engine somehow. The clutch allows us to smoothly engage a spinning engine to a non-spinning transmission by controlling the slippage between them. To understand how a clutch works, it helps to know a little bit about friction.
When your foot is off the pedal, the clutch springs push the pressure plate against the clutch disc, which in turn presses against the flywheel. This locks the engine to the transmission input shaft, causing them to spin at the same speed
The amount of force the clutch can hold depends on the friction between the clutch plate and the flywheel, and how much force the spring puts on the pressure plate.
When the clutch pedal is pressed, a cable or hydraulic piston pushes on the release fork, which presses the throw-out bearing against the middle of the diaphragm spring. As the middle of the diaphragm spring is pushed in, a series of pins near the outside of the spring causes the spring to pull the pressure plate away from the clutch disc. This releases the clutch from the spinning engine.
What Can Go Wrong?
The most common problem with clutches is that the friction material on the disc wears out. The friction material on a clutch disc is very similar to the friction material on the pads of a disc brake, or the shoes of a drum brake -- after a while, it wears away. When most or all of the friction material is gone, the clutch will start to slip, and eventually it won't transmit any power from the engine to the wheels.
The clutch only wears while the clutch disc and the flywheel are spinning at different speeds. When they are locked together, the friction material is held tightly against the flywheel, and they spin in sync. It is only when the clutch disc is slipping against the flywheel that wearing occurs. So if you are the type of driver who slips the clutch a lot, you will wear out your clutch a lot faster.
Another problem sometimes associated with clutches is a worn throwout bearing. This problem is often characterized by a rumbling noise whenever the clutch engages.
  • 2 months later...
For Ian
RON, MON or PON?
Different rating systems are used in different countries and so not all numbers mean the same thing. You must be careful to also quote the measurement system used....... :blink:
To see why there are different numbers let us take a trip back in time to World War I, some of the older members will remember it :unsure: Aviators had a problem, many engines would suddenly self destruct through detonation, which is bad news when you're up in the air. An engine might run fine on one batch of fuel but blow holes in the pistons on the next batch. The fuels seemed the same, weighed the same and may have even come from the same factory.
The fuel companies tried to analysis and standardise the petrol, but were unable to weed out the bad batches. Therefore a standard test engine with a variable compression facility was built and the fuel to be tested run through it. This heavy duty, single cylinder engine would be warmed to a standard temperature and at a set rpm the compression increased until engine knock occurred. this would give its Highest Usable Compression Ratio (HUCR).
But with time it was discovered that different labs gave different results. So in an attempt to produce an unvarying standard, two reference fuels were chosen. The high reference was 2-2-4 trimethylpentane (iso-octane), while the low reference was normal heptane (n-heptane). Once the HUCR was determined a mix of these to fuels was made up that exactly produced the same results as the HUCR test. The result is quoted as the percentage of iso-octane. Hence a petrol that detonated the same as a mix of 90% iso-octane and 10% n-heptane is called a 90 octane fuel.
Since that time a number of tests have come into being to simulate a variety of engine conditions. Motor Spirit is usually rated using the Research or Motor test methods. Both use the same old engine but under different conditions
Motor Octane Test (MON) Research Octane Test (RON)
Inlet air temperature 148.9 C 65.6 C
Engine jacket temp 100 C 100 C
Engine RPM 900 600
As you can see the Motor Octane Test employs a higher temperature and RPM and hence is probably a better indicator for today's engines. Of course the Research octane test gives a higher number and that's why the European manufacturers quote it (RON)
The spread between the two numbers is know as the fuels sensitivity, and it is very important. Because of the variety of engines it is possible for a petrol manufacturer to come up with a fuel that has a high RON, but a lower than expected MON. Hence although it looks normal on the pump it may perform badly. However on another day the same company may make its fuel out of a different blend to get the same RON but a different MON. This is done for profit reasons and is why you occasionally get bad fuel even though it is legally rated the same. In the past with high leaded fuels nobody noticed but nowadays high performance cars do notice.
In the USA the service stations use the Pump Octane Number or PON rather than RON. this is the average of RON and MON and gives a much better grade, and is also why the American gas always seems not as good as our when in fact it is is the same (and has better quality control). But even this system can be abused by adding octane boosters to poor fuel.
Below is an approximate comparison chart, these numbers can vary by as much as 2 grades
RON......MON......PON
90..........83........86.6
92..........85........88.5
95..........87........91
96..........88........92
98..........90........94
100........91.5.....95.8
105........95........100
110........99........104.5
So now Ian. you know far more you wanted to about RON, MON and PON. :)
Knowing this you might begin to wonder why certain garages are always cheaper than others, and experiment with different fuels.
SKEGNESS AND ITS ROOTS
Skegness once extended much further out to sea and the coastline has suffered erosion over many years though it is now gaining ground. We know that the area has been occupied since before Roman times. Roman pottery can be found today on the shore, it makes a change from collecting sea shells! Salt was manufactured along much of the low lying coast of Lincolnshire in Roman times and evidence of their working sites and even artifacts bearing their fingerprints can still be found today.
To come nearer to our time it is interesting to see how Skegness has altered in the last 150 years. In White's Directory for 1842 we read that Skegness had a population of only 185 people, it is described as a `pleasant village'. At that time there were only two hotels and several private lodging houses but even then bathing machines were stationed on the beach and there was a lifeboat to rescue survivors of the many small fishing boats which found themselves in trouble. It was also a small port with `upwards of 6000 tons of coal being landed here in the summer of 1841'.
Visiting the seaside became ever more popular over the years though at first only the better off people were able to take advantage of the facilities provided. In the 1870's the Earl of Scarborough, landowner of Skegness at that time, decided to improve the town and with estate agent V.Tippet plans were drawn up for new streets and houses which extended to what is now Scarborough Avenue. This was a piece of very advanced planning for the time. The area was laid out in a very sensible geometric pattern with wide roads, wide verges and footpaths, all of these are still adequate even for today's traffic.
It was not until the coming of the railway to Skegness in 1873 that the town really began to grow. The rail link with the midland towns meant it was possible for the working class people to spend a day at the seaside. At first there was only a single line and it was not until 1900 that it was made a double track. Winston Kyme in his book, `Skeggy the story of a seaside town' says that on August Bank Holiday 1882 the railway brought 22,000 day trippers to Skegness. 20,000 of them paid to go on to the pier which had only just been erected. By this time the population of Skegness had grown to 1400.
The erection of the gas works took place in 1875 and the town boasted 56 street lamps. White's Directory of 1882 describes the construction of the north and south promenades on the sea wall, costing £2,000 (in pre-decimal money) and being officially opened in 1879.
Very early on amusements of various kinds were thought up to amuse the visitors. Donkey races on the beach in front of the Sea View Hotel (built in 1862) attracting thousands of people. (For more information on this see The Book of the Lincolnshire Seaside by David Robinson). Sea water baths were built in 1882 on Scarborough Avenue, these were bombed during the war and have since been demolished.
The first car number plate was issued in 1903 and as cars became popular people began to come and stay for longer than a day trip. This resulted in more hotels and lodging houses being built and more and more amusements supplied for the visitors. A giant figure eight railway was built in 1908 on the new foreshore beyond the north parade. It was demolished in 1970.
The person who made the biggest impression on Skegness and district holiday trade was Billy Butlin.
He came to Skegness in 1921, a poor traveling showman. He entertained the holidaymakers with his hoop-la stalls. By 1929 he had opened a large amusement park on the south side of the pier. By 1935 he had built the Butlins Holiday Camp between Skegness and Ingoldmells. This went from success to success and many famous entertainers served their apprenticeship at Butlins Theatre. During the second world war it was used by the Royal Navy and re-named H.M.S Royal Arthur. It was returned to Butlins in 1946 and run successfully until 1972 when it was bought by the Rank Organisation and re-named yet again, this time as Funcoast World. In 1997-8 the theatre was demolished along with the famous wooden chalets in which generations of families had spent their holidays. Substantial blocks of flats built on the site have now given it the appearance of a small village. Meantime Skegness has grown to a famous holiday town having a resident population of around 17,000.
The Legendary Origins of Tea
The story of tea began in ancient China over 5,000 years ago. According to legend, Shen Nung, an early emperor was a skilled ruler, creative scientist and patron of the arts. His far-sighted edicts required, among other things, that all drinking water be boiled as a hygienic precaution. One summer day while visiting a distant region of his realm, he and the court stopped to rest. In accordance with his ruling, the servants began to boil water for the court to drink. Dried leaves from the near by bush fell into the boiling water, and a brown liquid was infused into the water. As a scientist, the Emperor was interested in the new liquid, drank some, and found it very refreshing. And so, according to legend, tea was created. (This myth maintains such a practical narrative, that many mythologists believe it may relate closely to the actual events, now lost in ancient history.)
The Chinese Influence
Tea consumption spread throughout the Chinese culture reaching into every aspect of the society. In 800 A.D. Lu Yu wrote the first definitive book on tea, the Ch'a Ching. This amazing man was orphaned as a child and raised by scholarly Buddhist monks in one of China's finest monasteries. However, as a young man, he rebelled against the discipline of priestly training which had made him a skilled observer. His fame as a performer increased with each year, but he felt his life lacked meaning. Finally, in mid-life, he retired for five years into seclusion. Drawing from his vast memory of observed events and places, he codified the various methods of tea cultivation and preparation in ancient China. The vast definitive nature of his work, projected him into near sainthood within his own lifetime. Patronized by the Emperor himself, his work clearly showed the Zen Buddhist philosophy to which he was exposed as a child. It was this form of tea service that Zen Buddhist missionaries would later introduce to imperial Japan.
The Japanese Influence
The first tea seeds were brought to Japan by the returning Buddhist priest Yeisei, who had seen the value of tea in China in enhancing religious mediation. As a result, he is known as the "Father of Tea" in Japan. Because of this early association, tea in Japan has always been associated with Zen Buddhism. Tea received almost instant imperial sponsorship and spread rapidly from the royal court and monasteries to the other sections of Japanese society.
Tea was elevated to an art form resulting in the creation of the Japanese Tea Ceremony ("Cha-no-yu" or "the hot water for tea"). The best description of this complex art form was probably written by the Irish-Greek journalist-historian Lafcadio Hearn, one of the few foreigners ever to be granted Japanese citizenship during this era. He wrote from personal observation, "The Tea ceremony requires years of training and practice to graduate in art...yet the whole of this art, as to its detail, signifies no more than the making and serving of a cup of tea. The supremely important matter is that the act be performed in the most perfect, most polite, most graceful, most charming manner possible".
Such a purity of form, of expression prompted the creation of supportive arts and services. A special form of architecture (chaseki) developed for "tea houses", based on the duplication of the simplicity of a forest cottage. The cultural/artistic hostesses of Japan, the Geishi, began to specialize in the presentation of the tea ceremony. As more and more people became involved in the excitement surrounding tea, the purity of the original Zen concept was lost. The tea ceremony became corrupted, boisterous and highly embellished. "Tea Tournaments" were held among the wealthy where nobles competed among each other for rich prizes in naming various tea blends. Rewarding winners with gifts of silk, armor, and jewelry was totally alien to the original Zen attitude of the ceremony.
Three great Zen priests restored tea to its original place in Japanese society:
Ikkyu (1394-1481)-a prince who became a priest and was successful in guiding the nobles away from their corruption of the tea ceremony.
Murata Shuko (1422-1502)-the student of Ikkyu and very influential in re-introducing the Tea ceremony into Japanese society.
Sen-no Rikkyu (1521-1591)-priest who set the rigid standards for the ceremony, largely used intact today. Rikyo was successful in influencing the Shogun Toyotomi Hideyoshi, who became Japan's greatest patron of the "art of tea". A brilliant general, strategist, poet, and artist this unique leader facilitated the final and complete integration of tea into the pattern of Japanese life. So complete was this acceptance, that tea was viewed as the ultimate gift, and warlords paused for tea before battles.
Europe Learns of Tea
While tea was at this high level of development in both Japan and China, information concerning this then unknown beverage began to filter back to Europe. Earlier caravan leaders had mentioned it, but were unclear as to its service format or appearance. (One reference suggests the leaves be boiled, salted, buttered, and eaten!) The first European to personally encounter tea and write about it was the Portuguese Jesuit Father Jasper de Cruz in 1560. Portugal, with her technologically advanced navy, had been successful in gaining the first right of trade with China. It was as a missionary on that first commercial mission that Father de Cruz had tasted tea four years before.
The Portuguese developed a trade route by which they shipped their tea to Lisbon, and then Dutch ships transported it to France, Holland, and the Baltic countries. (At that time Holland was politically affiliated with Portugal. When this alliance was altered in 1602, Holland, with her excellent navy, entered into full Pacific trade in her own right.)
Tea Comes to Europe
When tea finally arrived in Europe, Elizabeth I had more years to live, and Rembrandt was only six years old. Because of the success of the Dutch navy in the Pacific, tea became very fashionable in the Dutch capital, the Hague. This was due in part to the high cost of the tea (over $100 per pound) which immediately made it the domain of the wealthy. Slowly, as the amount of tea imported increased, the price fell as the volume of sale expanded. Initially available to the public in apothecaries along with such rare and new spices as ginger and sugar, by 1675 it was available in common food shops throughout Holland.
As the consumption of tea increased dramatically in Dutch society, doctors and university authorities argued back and forth as to the negative and/or positive benefits of tea. Known as "tea heretics", the public largely ignored the scholarly debate and continued to enjoy their new beverage though the controversy lasted from 1635 to roughly 1657. Throughout this period France and Holland LED Europe in the use of tea.
As the craze for things oriental swept Europe, tea became part of the way of life. The social critic Marie de Rabutin-Chantal, the Marquise de Seven makes the first mention in 1680 of adding milk to tea. During the same period, Dutch inns provided the first restaurant service of tea. Tavern owners would furnish guests with a portable tea set complete with a heating unit. The independent Dutchman would then prepare tea for himself and his friends outside in the tavern's garden. Tea remained popular in France for only about fifty years, being replaced by a stronger preference for wine, chocolate, and exotic coffees.
Tea Comes to America
By 1650 the Dutch were actively involved in trade throughout the Western world. Peter Stuyvesant brought the first tea to America to the colonists in the Dutch settlement of New Amsterdam (later re-named New York by the English). Settlers here were confirmed tea drinkers. And indeed, on acquiring the colony, the English found that the small settlement consumed more tea at that time then all of England put together.
Tea Arrives in England
Great Britain was the last of the three great sea-faring nations to break into the Chinese and East Indian trade routes. This was due in part to the unsteady ascension to the throne of the Stuarts and the Cromwellian Civil War. The first samples of tea reached England between 1652 and 1654. Tea quickly proved popular enough to replace ale as the national drink of England.
As in Holland, it was the nobility that provided the necessary stamp of approval and so insured its acceptance. King Charles II had married, while in exile, the Portuguese Infanta Catherine de Braganza (1662). Charles himself had grown up in the Dutch capital. As a result, both he and his Portuguese bride were confirmed tea drinkers. When the monarchy was re-established, the two rulers brought this foreign tea tradition to England with them. As early as 1600 Elizabeth I had founded the John company for the purpose of promoting Asian trade. When Catherine de Braganza married Charles she brought as part of her dowry the territories of Tangier and Bombay. Suddenly, the John Company had a base of operations.
Afternoon Tea in England
Tea mania swept across England as it had earlier spread throughout France and Holland. Tea importation rose from 40,000 pounds in 1699 to an annual average of 240,000 pounds by 1708. Tea was drunk by all levels of society.
Prior to the introduction of tea into Britain, the English had two main meals-breakfast and dinner. Breakfast was ale, bread and beef. Dinner was a long, massive meal at the end of the day. It was no wonder that Anna, the Duchess of Bedford (1788-1861) experienced a "sinking feeling" in the late afternoon. Adopting the European tea service format, she invited friends to join her for an additional afternoon meal at five o'clock in her rooms at Belvoir Castle. The menu centered around small cakes, bread and butter sandwiches, assorted sweets, and, of course, tea. This summer practice proved so popular, the Duchess continued it when she returned to London, sending cards to her friends asking them to join her for "tea and a walking the fields." (London at that time still contained large open meadows within the city.) The practice of inviting friends to come for tea in the afternoon was quickly picked up by other social hostesses. A common pattern of service soon merged. The first pot of tea was made in the kitchen and carried to the lady of the house who waited with her invited guests, surrounded by fine porcelain from China. The first pot was warmed by the hostess from a second pot (usually silver) that was kept heated over a small flame. Food and tea was then passed among the guests, the main purpose of the visiting being conversation.
Tea Cuisine
Tea cuisine quickly expanded in range to quickly include wafer thin crustless sandwiches, shrimp or fish pates, toasted breads with jams, and regional British pastries such as scones (Scottish) and crumpets (English).
At this time two distinct forms of tea services evolved: "High" and "Low". "Low" Tea (served in the low part of the afternoon) was served in aristocratic homes of the wealthy and featured gourmet tidbits rather than solid meals. The emphasis was on presentation and conversation. "High" Tea or "Meat Tea" was the main or "High" meal of the day. It was the major meal of the middle and lower classes and consisted of mostly full dinner items such as roast beef, mashed potatoes, peas, and of course, tea.
Coffee Houses
Tea was the major beverage served in the coffee houses, but they were so named because coffee arrived in England some years before tea. Exclusively for men, they were called "Penny Universities" because for a penny any man could obtain a pot of tea, a copy of the newspaper, and engage in conversation with the sharpest wits of the day. The various houses specialized in selected areas of interest, some serving attorneys, some authors, others the military. They were the forerunner of the English gentlemen's private club. One such beverage house was owned by Edward Lloyd and was favored by shipowners, merchants and marine insurers. That simple shop was the origin of Lloyd's, the worldwide insurance firm. Attempts to close the coffee houses were made throughout the eighteenth century because of the free speech they encouraged, but such measures proved so unpopular they were always quickly revoked.
Tea Gardens
Experiencing the Dutch "tavern garden teas", the English developed the idea of Tea Gardens. Here ladies and gentlemen took their tea out of doors surrounded by entertainment such as orchestras, hidden arbors, flowered walks, bowling greens, concerts, gambling, or fireworks at night. It was at just such a Tea Garden that Lord Nelson, who defeated Napoleon by sea, met the great love of his life, Emma, later Lady Hamilton. Women were permitted to enter a mixed, public gathering for the first time without social criticism. As the gardens were public, British society mixed here freely for the first time, cutting across lines of class and birth.
Tipping as a response to proper service developed in the Tea Gardens of England. Small, locked wooden boxes were placed on the tables throughout the Garden. Inscribed on each were the letters "T.I.P.S." which stood for the sentence "To Insure Prompt Service". If a guest wished the waiter to hurry (and so insure the tea arrived hot from the often distant kitchen) he dropped a coin into the box on being seated "to insure prompt service". Hence, the custom of tipping servers was created.
Russian Tea Tradition
Imperial Russia was attempting to engage China and Japan in trade at the same time as the East Indian Company. The Russian interest in tea began as early as 1618 when the Chinese embassy in Moscow presented several chests of tea to Czar Alexis. By 1689 the Trade Treaty of Newchinsk established a common border between Russia and China, allowing caravans to then cross back and forth freely. Still, the journey was not easy. The trip was 11,000 miles long and took over sixteen months to complete. The average caravan consisted of 200 to 300 camels. As a result of such factors, the cost of tea was initially prohibitive and available only to the wealthy. By the time Catherine the Great died (1796), the price had dropped some, and tea was spreading throughout Russian society. Tea was ideally suited to Russian life: hearty, warm, and sustaining.
The samovar, adopted from the Tibetan "hot pot", is a combination bubbling hot water heater and tea pot. Placed in the center of the Russian home, it could run all day and serve up to forty cups of tea at a time. Again showing the Asian influence in the Russian culture, guests sipped their tea from glasses in silver holders, very similar to Turkish coffee cups. The Russians have always favored strong tea highly sweetened with sugar, honey, or jam.
With the completion of the Trans-Siberian Railroad in 1900, the overland caravans were abandoned. Although the Revolution intervened in the flow of the Russian society, tea remained a staple throughout. Tea (along with vodka) is the national drink of the Russians today.
Tea and America
It was not until 1670 that English colonists in Boston became aware of tea, and it was not publicly available for sale until twenty years later. Tea Gardens were first opened in New York City, already aware of tea as a former Dutch colony. The new Gardens were centered around the natural springs, which the city fathers now equipped with pumps to facilitate the "tea craze". The most famous of these "tea springs" was at Roosevelt and Chatham (later Park Row Street).
By 1720 tea was a generally accepted staple of trade between the Colony and the Mother country. It was especially a favorite of colonial women, a factor England was to base a major political decision on later. Tea trade was centered in Boston, New York, and Philadelphia, future centers of American rebellion. As tea was heavily taxed, even at this early date, contraband tea was smuggled into the colonies by the independent minded American merchants from ports far away and adopted herbal teas from the Indians. The directors of the then John Company (to merge later with the East India Company) fumed as they saw their profits diminish and they pressured Parliament to take action. It was not long in coming.
Tea and the American Revolution
England had recently completed the French and Indian War, fought, from England's point of view, to free the colony from French influence and stabilize trade. It was the feeling of Parliament that as a result, it was not unreasonable that the colonists shoulder the majority of the cost. After all, the war had been fought for their benefit. Charles Townshend presented the first tax measures which today are known by his name. They imposed a higher tax on newspapers (which they considered far too outspoken in America), tavern licenses (too much free speech there), legal documents, marriage licenses, and docking papers. The colonists rebelled against taxes imposed upon them without their consent and which were so repressive. New, heavier taxes were leveled by Parliament for such rebellion. Among these was, in June 1767, the tea tax that was to become the watershed of America's desire for freedom. (Townshend died three months later of a fever never to know his tax measures helped create a free nation.)
The colonists rebelled and openly purchased imported tea, largely Dutch in origin. The John company, already in deep financial trouble saw its profits fall even further. By 1773 the John Company merged with the East India Company for structural stability and pleaded with the Crown for assistance. The new Lord of the Treasury, Lord North, as a response to this pressure, granted to the new Company permission to sell directly to the colonists, by-passing the colonial merchants and pocketing the difference. In plotting this strategy, England was counting on the well known passion among American women for tea to force consumption. It was a major miscalculation. Throughout the colonies, women pledged publicly at meetings and in newspapers not to drink English sold tea until their free rights (and those of their merchant husbands) were restored.
BACK TO TOP The Boston Tea Party
By December 16 events had deteriorated enough that the men of Boston, dressed as Indians (remember the original justification for taxation had been the expense of the French and Indian War) threw hundreds of pounds of tea into the harbor: The Boston Tea Party. Such leading citizens as Samuel Adams and John Hancock took part. England had had enough. In retaliation, the port of Boston was closed and the city occupied by royal troops. The colonial leaders met and revolution was declared.
The Trade Continued in the Orient
Though concerned over developments in America, English tea interests still centered on the product's source-the Orient. There the trading of tea had become a way of life, developing its own language known as "Pidgin English". Created solely to facilitate commerce, the language was composed of English, Portuguese, and Indian words all pronounced in Chinese. Indeed, the word "Pidgin" is a corrupted form of the Chinese word for "do business".
So dominant was the tea culture within the English speaking cultures that many of these words came to hold a permanent place in our language.
"Mandarin" (from the Portuguese "mandar" meaning to order) - the court official empowered by the emperor to trade tea.
"Cash" (from the Portuguese "caixa" meaning case or money box)-the currency of tea transactions.
"Caddy" (from the Chinese word for one pound weight)-the standard tea trade container.
"Chow" (from the Indian word for food cargo)-slang for food.
The Opium Wars
Not only was language a problem, but so was the currency. Vast sums of money were spent on tea. To take such large amounts of money physically out of England would have financially collapsed the country and been impossible to transport safely half way around the world. With plantations in newly occupied India, the John Company saw a solution. In India they could grow the inexpensive crop of opium and use it as a means of exchange. Because of its addictive nature, the demand for the drug would be lifelong, insuring an unending market.
Chinese emperors tried to maintain the forced distance between the Chinese people and the "devils". But disorder in the Chinese culture and foreign military might prevented it. The Opium Wars broke out with the English ready to go to war for free trade (their right to sell opium). By 1842 England had gained enough military advantages to enable her to sell opium in China undisturbed until 1908.
America Enters the Tea Trade
The first three American millionaires, T. H. Perkins of Boston, Stephen Girard of Philadelphia, and John Jacob Astor of New York, all made their fortunes in the China trade. America began direct trade with China soon after the Revolution was over in 1789. America's newer, faster clipper ships outsailed the slower, heavier English "tea wagons" that had until then dominated the trade. This forced the English navy to update their fleet, a fact America would have to address in the War of 1812.
The new American ships established sailing records that still stand for speed and distance. John Jacob Astor began his tea trading in 1800. He required a minimum profit on each venture of 50% and often made 100%. Stephen Girard of Philadelphia was known as the "gentle tea merchant". His critical loans to the young (and still weak) American government enabled the nation to re-arm for the War of 1812. The orphanage founded by him still perpetuates his good name. Thomas Perkins was from one of Boston's oldest sailing families. The Chinese trust in him as a gentleman of his word enabled him to conduct enormous transactions half way around the world without a single written contract. His word and his handshake was enough so great was his honor in the eyes of the Chinese.
It is to their everlasting credit that none of these men ever paid for tea with opium. America was able to break the English tea monopoly because its ships were faster and America paid in gold.
The Clipper Days
By the mid-1800's the world was involved in a global clipper race as nations competed with each other to claim the fastest ships. England and America were the leading rivals. Each year the tall ships would race from China to the Tea Exchange in London to bring in the first tea for auction. Though beginning half way around the world, the mastery of the crews was such that the great ships often raced up the Thames separated by only by minutes. But by 1871 the newer steamships began to replace these great ships.
Global Tea Plantations Develop
The Scottish botanist/adventurer Robert Fortune, who spoke fluent Chinese, was able to sneak into mainland China the first year after the Opium War. He obtained some of the closely guarded tea seeds and made notes on tea cultivation. With support from the Crown, various experiments in growing tea in India were attempted. Many of these failed due to bad soil selection and incorrect planting techniques, ruining many a younger son of a noble family. Through each failure, however, the technology was perfected. Finally, after years of trial and error, fortunes made and lost, the English tea plantations in India and other parts of Asia flourished. The great English tea marketing companies were founded and production mechanized as the world industrialized in the late 1880's.
Tea Inventions in America: Iced Tea and Teabags
America stabilized her government, strengthened her economy, and expanded her borders and interests. By 1904 the United States was ready for the world to see her development at the St. Louis World's Fair. Trade exhibitors from around the world brought their products to America's first World's Fair. One such merchant was Richard Blechynden, a tea plantation owner. Originally, he had planned to give away free samples of hot tea to fair visitors. But when a heat wave hit, no one was interested. To save his investment of time and travel, he dumped a load of ice into the brewed tea and served the first "iced tea". It was (along with the Egyptian fan dancer) the hit of the Fair.
Four years later, Thomas Sullivan of New York developed the concept of "bagged tea". As a tea merchant, he carefully wrapped each sample delivered to restaurants for their consideration. He recognized a natural marketing opportunity when he realized the restaurants were brewing the samples "in the bags" to avoid the mess of tea leaves in the kitchens.
Tea Rooms, Tea Courts, and Tea Dances
Beginning in the late 1880's in both America and England, fine hotels began to offer tea service in tea rooms and tea courts. Served in the late afternoon, Victorian ladies (and their gentlemen friends) could meet for tea and conversation. Many of these tea services became the hallmark of the elegance of the hotel, such as the tea services at the Ritz (Boston) and the Plaza (New York).
By 1910 hotels began to host afternoon tea dances as dance craze after dance craze swept the United States and England. Often considered wasteful by older people they provided a place for the new "working girl" to meet men in a city, far from home and family. (Indeed, the editor of Vogue once fired a large number of female secretarial workers for "wasting their time at tea dances").
Afternoon Tea Today in the USA
Tea is more popular than ever in America today. Currently, there is a re-awakening of interest in tea as many Americans seek a more positive, healthy lifestyle. Fine hotels throughout the United States are re-establishing or planning for the first time afternoon tea services.
Prefer Coffee myself:
Coffee beans were chewed raw for centuries in Ethiopia and Yemen. Excavations in the Ethiopian highlands where coffee grows wild indicates human gathers have been eating coffee berries over a hundred thousand years. The fleshy pulp around the coffee bean in Ethiopian coffee has a high sugar content. Being sweet, being nutritious, and seeds, nuts, grapes and berries being generally eaten by humans for over a million years sort of supports this theory.
Ugandans were noticed chewing dried coffee beans when the first explorers from Europe were searching for the origin of the Nile river. Green coffee beans were ground up and mixed with fat, then made into small balls, which were eaten by travellers on long journeys. Some say this is the first trail mix.
Stories in the Southern Arabian peninsula known as Yemen where Europeans first found the coffee plant cultivated support the coffee bean being traded as early as 800 BC. Facts support trade between Yemen and Ethiopia during this time. Knowing how eating the coffee berry acts on people, it would be logical that those early traders would attempt to trade this item. Additionally, evidence does not support the coffee plant would grow wild in Yemen but was cultivated instead. Although, it is possible that a large bird could have carried the coffee berry that far, it is not likely.
No specific historic event is involved in coffee arriving in Southern Arabia but Ethiopia did invaded Southern Arabia in 525 AD. Many speculate that coffee could have been introduced to Arabia at this time. Some historians say coffee was introduced into Arabia by slave traders who raided Africa as early as 1000 BC.
The two things that support the theory that coffee spread very early in civilized trade are coffee's affect on people and old Arabian stories. Here is one such story:
Once upon a time in Arabia, there lived a goat herder named Kaldi. Kaldi was a sober and responsible goat herder. One day, Kaldi's goats didn't come home so he went looking for them. He found them hopping with glee acting in an eccentric behavior around a shiny dark-leafed shrub with red berries. Kaldi noted that the goats were eating the red berries. So, he tried the berry. Kaldi was soon dancing around the tree too.
A learned man from a local town named Aucuba came by, he was sleepy, tired, and hungry. Aucuba saw Kaldi acting wildly. He saw the goats acting wildly too. Because he was hungry he tried the berries. He became wide awake and was instantly ready to keep traveling. He took some berries back to his town and used it with other foods. He mixed the berries with drinks at his monastery which kept people awake during prayer. It then spread to other towns and monasteries. Aucuba became a rich man. No one knows what happen to Kaldi.
