Programming New Key Fob Help!
hi guys
i have tryed all in the Reprogramming Key Fob threads but failed
my car is a may03 reg se when am on step 5 in the 2ND VERSION SLIGHTLY DIFFERENT the light continuous to flash i waited for more than 2 mins
still no luck
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and
remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
For 2002+ Toyota, Lexus
Add Duplicate Key
Requires one working Toyota/Lexus Master Key.
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the driver side door 6 times.
5. Remove the Master Key and insert the new duplicates key.
6. TURN THE IGNITION CYLINDER ON.
7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
To program the immobilizer bit of your new key:
First, have your new key cut. Then:
For 1998+ Toyota, Lexus
Add Duplicate Key
remove key.
To make your Lexus remember your key's wireless signal:
For the remote part in drivers seat WITH DOOR OPEN.
Start with door unlocked.
1. Put master key in ignition, turn to on, then back off and remove.
2. Using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
3. Close drivers door, open drivers door.
4. Perform lock/unlock procedure again. DO NOT close and open drivers door. Just the lock/unlock procedure again.
5. Insert NEW key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
6. Now press both lock and unlock buttons on REMOTE. Release after about 1.5 seconds.
7. Now press just the lock button on remote.
once you press the lock button, the car should lock and unlock ONCE, if it lock unlocked TWICE you messed up somewhere.
8. Now open and close the drivers door a couple times to close programming.
if you did it right, remote will now work."
wahid
hi guys
still no luck
remove key.
hi,programmed mine ok and is working fine although had to do it a few times before getting it right,used a slightly different version though,will see if i can add it on later on today hopefully.
Add Duplicate Key
4. Open and close the “driver side” door 6 times.
Add Duplicate Key
remove key.
wahid
anyone???
I dont know what other dealers charge but we charge £25 + vat to code.
Have you got the correct fob for the car?
Andy
hi mate
i think i have
this what it says on the back clbt/c/245/2009 denso 1512v and the lexus logo
wahid
anyone???
Andy
hi mate
i think i have
wahid
bump!!!!
anyone???
Andy
hi mate
i think i have
wahid
bump!!!!
What I need are the numbers on the Battery cover of the remote itself not the key.
Andy
anyone???
Andy
hi mate
i think i have
wahid
bump!!!!
Andy
hi mate
on the cover it says c123.7 its got a white sticker on the back but the numbers are faded away i think it gos like this b907105 and the rest is scruff up
and its got the Battery number (cr2016)
thanks
wahid
Sorry mate , we have our wires crossed. I mean the battery cover on the transponder case not the key case.
Andy
that is what is says on the transponder case mate
its got a white sticker on it b907105 cant read the rest
thanks
wahid
Andy
thanks
wahid
OK, IS remotes do not have stickers that I have ever seen, Battery id should be cr1616 so it sounds like you do not have the correct remote :(
Andy
Andy
thanks
wahid
Andy
thanks mate
would you now which lexus uses the cr2016 Battery mate? so i can sell it on eBay
i think its for the ls400
wahid
update
got it to work
well i did buy a 2nd tranmitter from eBay from this guy http://shop.ebay.co.uk/pot_of_gold_7...&_trksid=p3686
and it worked first time
thanks to all you guys for your help
this what i did worked for me on a is200 03 reg
thanks to scudney :)
TO LOCK CAR
open drivers side door and remove key from ignition switch
insert key to be programmed into ignition switch then remove it
Within 40 seconds
1. Press lock and unlock on the vehicle door control switch at 1 second intervals 5 times
2. Close and reopen drivers door
Within 40 seconds
2. Insert key into ignition switch
3.Switch ignition ON and OFF once to program new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes.
4. Remove key from ignition switch.
System should now lock and unlock car once or twice depending which mode has been selected
Within 40 seconds
1.Simultaneously press and hold key lock and unlock buttons for a maximum of 1.5 seconds.
2.Within 3 seconds press any key button for a minimum of 1 second.
Note:if system locks and unlocks car twice,progranmming procedure has not been completed.Repeat programming procedure
and get the car start
TO PROGRAMME IMMOBILIZER
Insert programmed black key into ignition switch
Within 15 seconds
1. Press and release accelerator pedal 5 times
Within 20 seconds
1. Press and release brake pedal 6 times
2. Remove black key
Within 10 seconds
Insert black key to be programmed into ignition switch
Within 10 seconds
Press and release accelerator pedal once. Immobilizer warning light will flash
After 1 minute Immobilizer warning light will extinquish.
To exit programming mode:remove ignition key and press brake pedal atleast once with 10 seconds or wait 10 seconds
wahid
update
got it to work
well i did buy a 2nd tranmitter from ebay from this guy http://shop.ebay.co.uk/pot_of_gold_7...&_trksid=p3686
TO LOCK CAR
Within 40 seconds
Within 40 seconds
Within 40 seconds
Within 15 seconds
Within 20 seconds
2. Remove black key
Within 10 seconds
Within 10 seconds
wahid
Glad to hear you got sorted :)
Andy
  • 4 years later...
anyone???
Andy
anyone???
Andy
Hi would you send me your address and details to have my key fob reprogramed as i cannot start it and cannot close the doors it fits the ignition and turns over but will not start we think it is the imobiliser we hope thank you send it to my Dads EMAIL ADDRESS PLEASE as he looks every day on his email thank you hope to hear from you Scott
Sorry to be the bearer of bad news.
Andy (ACLex) has left the Lexus dealership at Poole. Some months back in fact.
Try your nearest dealership up where you are.
Have you tried the method listed further back up the page. Might just work. I have something similarish written down for my wife's Mx5....and it worked...thank heavens. we were up a hill in Annecy in France!!!!!!! So glad I kept a note hidden in the car.
hi mate
try this first
TO LOCK CAR
Within 40 seconds
Within 40 seconds
Within 40 seconds
Within 15 seconds
Within 20 seconds
2. Remove black key
Within 10 seconds
Within 10 seconds
if not i think you have the wrong key/trasmitter?
it should be like this
http://www.ebay.co.uk/itm/GENUINE-LEXUS-IS200-GS300-LS400-RX300-ETC-3-BUTTON-REMOTE-ALARM-UNCUT-KEY-FOB-/331508619726?pt=LH_DefaultDomain_3&hash=item4d2f7419ce#ht_515wt_1222
Wahid
  • 2 years later...
On 21/03/2015 at 10:28 AM, wahid hussian said:
hi mate
try this first
TO LOCK CAR
Within 40 seconds
Within 40 seconds
Within 40 seconds
Within 15 seconds
Within 20 seconds
2. Remove black key
Within 10 seconds
Within 10 seconds
Wahid
I tried reprogramming an old remote (I had from a former Is200 i wrote it off) that  I placed in a new key shell. The remote lock when worked fine after a few times.
i did find out that what is meant by « 3.Switch ignition ON and OFF once to program new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes «  is that it will erase the codes from the orignal key. So I had then to reprogram that one.
However I can’t get the immobiliser programmed in my old remote, from my old written off Lexus (R.I.P).
is that normal or should I keep trying? Done it about 10 time with no success
