Shim Kits
FLEXA
ok guys found aftermarket shimkits for £10 for front and a brake fitting kit £8 for the rear...way cheaper than what i was quoted at dealers.. they are branded APEX and are available from www.livingstonautoparts.co.uk... the anti-rattle clip for the rear calipers are £34.00 from dealers (this is for both sides including the pins). you can buy just the clip for £5.90. hope this helps
where did you buy your shim kit from..
any diffrence
will these stop brake squeal, mine is currently doing my nut in
should do,, try phoning livingston auto parts (i think they list it as a brake fitting kit) otherwise try a universal kit from eBay item number is 250695039221..or search "universal shims) thats £7.00 delivered.
