Missfire
woodstock
Hi i have a bad misfire on my lexus gs300 1995 i have had it into garage and had new plugs fitted all the leads checked the ecu reset and been checked for any air leaks and found none this problem started when the wet weather started could anyone advise me as to what may be the cause im having problems getting a diognostic test done and my nearest lexus garage is nearly 80 miles away many thanks
kevin
