How Do I Open The Remote Key?
finally got my replacement batteries through the post yesterday for the key fob...
so now the problem is how to i open the remote key?
it has the smallest philip screw head.... where do i find a screw driver small enough to open it with messing the screw up?
thanks
thanks
Hi,if you can't get hold of a set of small screw drivers,take it to a shop that changes watch batteries or car key fob batteries and they should be able to do it for you,I changed mine myself.
Although the screw is a small cross-head, I found that it was not very tight and managed to remove it (with care) using a small ordinary straight blade jeweller's screwdriver. A set of these small screwdrivers is quite cheap and comes in very useful now and again.
