Engine Problem
Hi All
On the way back home from work car started to run a bit rough no ecu light.
Had to pop out so went back out in car and was still a bit rough then ECU light was flashing. Turned round went home.
The code is P0301, missfire cylinder 1. Changed the plug still the same, so assume coilpack?
Am I right?
If so anyone got a couple for sale cheap?
