Coilover Sleeve Kits
chloesdaddy
  • 4 months later...
hi there does any one know where to get a coilver sleeve kit for my is200 i know about skunk 2 kits but am wondering what othe kits are availible and at best price and has anyone had any experience of this type of kit on a is200 cheers james
hi ive seen these to.. im guessing these slide over the standard damper?? if so i wouldnt really want to go with that option... as if they go lower than say 40mm for example there going to put much more stress on the standard damper, thus shortening the life of the dampers... if i were you id spend a bit more and just get full coloivers with the damper to suit the varying ride heights possible as then they have the right spring rate for the damper... im no mechanic but its what i see as being logical..???
