Trc Lights/engine Management
I loaded my is200 with 5 pavement slabs this afternoon,and even though it's lowered 40mm,it was no problem drivin,it actually felt good,anyways took a trip to the airport tonight and my TRC light flashing and the malfunction indicator lamp staying on,the car is still pulling and no loss of power,any ideas,im thinking about the concrete slabs that i had in the boot earlier on upsetting something,im gonna reset ecu,remove Battery tommorow,any ideas what it could be? :ohmy:
Flashing TRC light normally indicates a faulty ABS/wheel speed sensor. Could be something as simple as one has come unplugged or the connection is dirty or at worst it needs replacing. Best see if you can get a fault code out of it first.
