Top Speed
Hey Guys,
Was looking through the spec sheet for the IS200, it says Manual top speed 134mph.
Not being funny but I hit 140mph maybe 141mph?????
What do you guys think?
Only if you drove it off a cliff...... Your speedometer always reads optimistically, they are designed to do so... More so if your rear tyres are worn..
Hi when you are speed testing ( on a private road :winky: ) bear in mind your speedo will normally read 10% higher than your actual speed -so 140 = 126 ; If you have a sat nav set it on a steady speed for as long as possible (on your private road again)and you will see the difference to compare with your indicated speed
