Shall I Do This To My Car In Half Hour?
Grim posted the following combination on a different thread a while ago. I checked on the lextasy site and this is what it says (for IS300 I think though). I trust it, however, am wary about playing with my car in this manor. Should I do it do you think?
Tony
Taken from the Lextasy Site
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
if this really works i'm never parking my car anywhere that you have to leave the key or any valet etc. since it's a really easy way to copy the key and steal the car at a later date without having to break in to the car or draw attention to yourself.
didn't work :(
in the slightest.......lights just did as normal.
i tried with keys in pre-ignition point, just in.
not messed up my car tho which is good......all still works as it should. Just means I have to make the hours trip to lexus to get it done :(
Tony
This sounds like a bit of wind-up, to me, funny way to re-program keys.
are you sure you don't have to get of the car and then hop all the way round on one leg and then get back in.
