Is The Rear Lambda Sensor Needed?
hi all well after all my trying to get my new exhaust fitted which came with no lambda sensor hole in it i was going to weld a lug on the new pipe but i can not get the sensor out the old exhaust and i contacted the shop i got the cat back system from they said that the reason they dont put a hole in is because the rear sensor is not needed so i fort i would ask on here if it is needed? any help is good thanks again.
