Handbrake Warning Light
smalls
hi just changed front and rear pads on my is, now when i turn ignition on and release handbrake light goes of as normal, but when i start driving and press the brakes the warning light comes on and stays on till i turn the car off. any help much appreciated.
u have either a loose brake light bulb or one has gone altogether and needs replacing, thats all,
the fact that it is happening since changing pads i think is just coincidence, just check ur brake bulbs
hi,as mentioned by some others u very likely have a blown bulb thats all okay.
Hi to all! I have the same problem staring from last week and i have tried everything: pads, light bulbs, switches, connectors, break fluid, but I've totally forgot about the third break light between the rear speakers witch was dead. So before you start with other more serious checks pay attention to all three break lights on the back of the car.
Regards, Adrian!
