I need to change the front N/S sidelight bulb (surprised that there was no indication on the dash to say it was out), and am having difficulty removing the indicator assembly to get access (Mk 4).
The owners handbook says to remove the philips screw, then pull up the base of the indicator unit and pull out (forward and up). Well, I've tried, and it seems that it may break if I use any more force. Any ideas?
Pete
Did this very same job on my MK4 about three weeks ago. Yes, the instructions to remove the headlamp unit are correct as follows:
Remove black philips screw from top-right of unit which connects it to the indicator case.
Grip bottom of indicator case and pull forward and slightly up. (knowing this was the only way, I simply applied additional force until the indicator case popped out).
This will then reveal 2 more 10mm bolts holding the headlamp unit in place.
Remove 4x 10mm bolts and the headlamp unit will be released.
Pull unit forward and to the left simultaneously, you can't just pull forward (you'll figure that one out when it catches on the surrounding frame).
Sidelamp connector (black? circular holder) is at the top (not to be confused with the 2 larger lamp connectors hidden behind grey covers).
Twist and pull.
Remove blown bulb and replace.
Re-insert holder into headlamp unit and twist back.
Now simply refit the unit in reverse order...
Hope this helps..
Now sorted :D
Once I knew that it was only a matter of force, I used a large screwdriver at the lower edge of the indicator unit and pried it out (used a leather glove to bear against to avoid paint damage). It actually didn't require much force - in fact I know it would have broken had I continued to use just my fingers to pull it out.
Headlight came out no bother, and all bolts replaced using copaslip (and the studs on indicator unit) for the next time.
Pete
