Replacing Bulbs Behind Climate Control Unit
Jay G
Hi guys,
A couple of my LEDs behind the left and centre dial (fan type and temperature dial) have blown. I want to attempt replacing these myself but am yet to find a instructions / guide on the forums showing steps required. I have found this document by Hando a useful starting point for disconnecting the sat nav device.
Can anyone point me in the right direction or provide link if already covered on the forums? I know I will need the T5 bulbs from a previous post. I just want to keep it simple and replace them with the same colour.
Thanks,
Jay
Hi guys,
Thanks,
Jay
Hi there, you may find there is T3 bulbs too theres 2 of one and 3 of the other. any way on top of the ac unit under sat nav panel you will find 2x 10mm bolts (gold) and if you pull the heated seat buttons panel you will also find 2x 10mm bolts (gold) removing these will free your ac unit and cd player in one you can then unplug and get to the back to change bulbs if required you can seperate ther ac and cd player with i think 8mm bolts. MAKE SURE YOU HAVE RADIO CODE BEFORE UNPLUGGING IT. hope this helps
