I cannot get FM reception on my radio,the cd player had 6 discs inside and an err3 message.
So today i removed the head unit and got them pesky cd's out.
I still have an err3,i'm not too bothered about the cd player not working,but would like the radio to work.
Any suggestions for a fix for the radio or could it be knackered ?
I would like to keep a standard head unit if possible and have seen a used one for sale,in working order,but what sort of price should i expect to pay.
Thanks.
You may have accidently disconnected the power lead to the ariel. The ariel has an amplifier wich needs a power supply to work. From what I can remember there is a lead than comes from the connector on the back of the head unit and connects to a small socket on a lead which runs along side the ariel lead.
Dave
Dave
Thanks.
I made sure all the connections where sound before bolting the unit back in place.Is there anywhere else i should be looking or do i replace the head unit
and hope it works?
ERR3 doesn't normally cause the radio to go as well, this is a separate fault. It could be the antenna needs replacing?
Well i bought a second hand head unit,and have only just fitted it.
Guess what? The radio works perfect and the cd :yahoo: As i said before i was'nt too bothered about the cd,but at least now i can listen to fm.
Just hope it lasts me a while as i really like the look of the stock unit.
Glad u got a result, i also ended up with crap fm reception on my stock unit, no error codes tho, checked every wire, all looked good, bought a double din unit, fitted that, still crap fm reception :sad:
