Sat Nav For 52 Plate Sc430
lester
You'll need to look at the number on the face of the disc, and then check HERE to confirm whether there is a later version available.
Thanks, I don't want to take the disc out in case it upsets it but I have an invoice for the last disc that was put in and that is Sat Nav CD rom L08927-50872. Would you know if this is the latest or if there is a later one. Look forward to your reply, cheers Lester
The answer is yes, and if you put your deatils of the one that is there into the site that Parthiban gave you the link it will tell you and it's 159 euros and it's a 2009 one.
Thanks for the reply, I did this and an error message came up 'no product found with that disc id '- am I doing something wrong?
