Oil Catch Tank
lexdavis
hi all
ive got an oil catch tank to fit just want to no if anyone has fitted one and if so did you make a custom bracket as there wasnt one supplied with it.
not sure how to fit it and to where
thanks
ormi looking towards you as i no you have one fitted
hi all
thanks
i mounted mine on the o/s/f inner wing pic will show..their is one hole just fit for a 10mm and i drilled and used a self tapper for the other
you should have got a bracket mate all the ones i have bought have come with the brackets.
the bracket shouldnt be to hard to make though just a square of sheet metal with a bend and 4 holes drilled.
p3009092152.jpg.
