Engine Cuts Off
rajesh
:whistling:
the engine cuts off - and ontop of that the Engine light started to come on....... - now i started again and its happened again & again......O no.....!!! 3 times in a 5min trip.....
no miss fireing or anything like that - just cuts off.... - had a look on the web, answers so far "spark plugs" - "Coil" - engin management System".
set to have a check tomrrow at my local Garage (i hope they dont rip me off, like they tried before) - anyway any ideas guys ?
the lights on while engine on are - "Engine - ABS (bottom left) - hope its not too bad......
your help is needed guys - i hope i get home safely tonight.......... :whistling:
Best thing to do is to get it to garage and get them to hook it up to a diagnostic machine/reader.
The dianogstic reader will generate codes- once you have the codes, then the garage can tell you what the problem is and what parts need replacing.
  • 4 weeks later...
