Vsc-egr Valve-cat Convert
Hi all who having VSC problems and ref my last post! I went to Lexus Hull and was told for sure it was the CATALITIC CONVERTER or PARTICULATE FILTER which is actually part of the cat anyway. Original quote Lexus HULL was £1,900 (***** turpin comes to mind) went to meet with service manager who git down to £1200. I went away seacrhed the NET and found one from a smashed rear end car in a breakers, covered only 18,000miles. Had it fitted for £100 and hey presto so far all is ok.
Lexus refused to replace under any warranty!!!! ive now covered some 140,000 since March 2007 and ready to get rid of the damn thing!!!
5 EGR VALVES ALSO FITTED!!!!!
NOW REAR SHOCKER HAS GONE AND THE AIRCON! Not that we need it in the Snow anyway
ADVISE!!! When the CHECK VSC ligts came on the service manger told me that this is a warning that a log has been stored in the computer, depending on the log it will place the car in get home mode where you willcrawl home or attempt to anyway!
I havent tried this but i was told if this happens disconnect the Battery for 10mins and it will clear the fault allowing the car to drive normal until you can get it to Lexus for them to rip you off!!!
Take a spanner with you in the car to take the batt terminals off!
Cheek of the sales guy though suggested i try the 09 model, far better engine he said !!! and will give me £5000 for my current car that cost £24,000 not even 3 years ago!!!!!
MM i think its time to go back to the German machines!
