Couple Of Random Problems
mattc
Ok then, couple of random issues with my 200
1) The passenger side mirror can't be moved with the controller (drivers works fine)
2) Passenger side mirror heating does not work (drivers works fine)
3) The passenger side air vent blows out colder air than all other vents
I have checked the fuse for the mirror looks ok, but can someone comfirm the right fuse location so I know that I've got the right one. Might change anyway
Comments welcome on all problems, Cheers
actually i have the same problem with my passenger mirror. on some occations, when i close my mirrors, the passanger wing mirror doesnt want to come out again even the driver side is opening fine.
i think it has something to do with the motor inside where the theeths which moves the mirror are getting a bit wonred off. when i give i a bit push it works just fine.
if you want to get it repaired it will proberly cost you about £200-300 from lexus. i much rather give it a bit push.
